17LimitedExpy
I can find the Power Point settings in the 2018 spreadsheet but there is no "data to the right" to see what changed need to be made. And the spreadsheet seems to only be a partial sheet with no way to download it. etc.
726-39-01 0101 0069 as my 2017 was built
726-39-01 ???? 0069 but no indication what to change the ???? to.
-- Chuck
It seems that several things are going on here, so I’ll try to answer as many as I can;
First, the 2018 Power Point code will not work on your 2017 (if that’s what you are trying to do)
Second, what device are you using to access the Google spreadsheet? Even on my iPad I can slide the 2018 sheet over to access the Power Point calculation link.
Third, will someone else try accessing the FORScan spreadsheet (post #684) to see if they have any errors? Sometimes Google will be down/not working properly.
I hope this helps.
