What Grade of Gas are you using?
Octane rating
  • <87
    Votes: 45 49.5%
  • 88-89
    Votes: 8 8.8%
  • >90
    Votes: 41 45.1%
  • I siphon gas from the neighbor
    Votes: 1 1.1%
  • I actually drive a Prius
    Votes: 1 1.1%
  • 100+ Racing Gas
    Votes: 1 1.1%
  • Total voters
    91
Boose
2017 Platinum EL
NJ
Premium. my local Costco has their premium at .20 over regular 2.79 vs. 2.59. The increased economy on the highway pays for it.
rjdelp7
2000 XLT
NY
The Ford Mustang GT 5.0 manual recommends 91 or higher for maximum performance. It will run with reduced performance on 87. Ford cleverly re-worded the Expedition manual. Basically, use 91 or higher for towing. In other words, it makes less power than advertised power on 87 octane.
Super Moderator
Super Moderator
Thanks for stating again what several of us said A LONG time ago.
EdWeg
Birmingham, AL
Has anyone ever seen any 'measured' and 'recorded' studies showing output comparisons between which grade you use?
Super Moderator
Super Moderator
YES! Posted above!
Car & Driver did an article and it included a 150 with the 2nd Gen 3.5.
Also, I have done A LOT of logging. You can watch the motor pull timing, which means less boost, and less power when running lower Octane fuel.
Even on 93 it pulls timing under extended heavy load, high ambient temps, or when the intake and everything gets heat soaked.
