I did the 19274 update this morning. I was surprised and a little unhappy to loose my Pandora phone app over blue tooth. I'm hoping it's just a setting or maybe the first time I run the app over usb it'll be saved. The message said, "SYNC-enabled Mobile Nav apps can only be found when connected via USB." Other than that, no issues and was about 5 min start to finish.
My Pandora works via BT on both my Expy and Edge on 19274. At least, last I tried a few days ago. I use CarPlay connected via USB 95% of the time.
Make sure Pandora is open on the phone. It can’t connect to it Via BT if the app hasn’t been opened recently on the Phone. If you force close the app or reboot your phone, Pandora will not be active. Just open it, and once it is open and in the background Applink should be able to connect.
