Limited - Ambient Lighting Not Showing in Sync
Moderator
No Ambient lighting setting in the Sync Settings menu in our new 2020 Limited. According to Ford’s website all Limited should have it.
2 Questions:
1). Anybody with a 4th Gen Limited that is also missing Ambient Lighting?
2). Anybody else ran in to this and found a fix if it was just a setting somewhere?
Thanks!
Moderator
Found It! In a COMPLETELY different place than my 4 other Fords with it.
No color option either. That make me sad, but at least some light in the floors now!
Moderator
@bushpilot mentioned something similar in post 287 of this thread.
https://www.expeditionforum.com/thr...the-latest-sync-3-4.42507/page-29#post-392257
He also has a 2020. My 2019 has the ability to change colors and dim. It would be nice to know if it is model year related or if it is related to sync 3.4.
The 2020’s have 3.4 from the factory. I upgraded mine from 19200 to 20021 today with no change.
Have you upgraded to 3.4? Would be curious if the setting remains.
Looks like I will be digging in to FORSCAN a bit on this new one later this week.
Wife has 3 12’s over the next 3 days, so it will have to wait until the weekend.
dlcorbett
Air Force
tx
Theres a known issue with the 2020 navs where the early builds didnt have the option in the sync hardware, but a quick download from the dealer put it back on. Maybe its the same with yours. They should all have colored ambient lighting, not jus blue colored lights.
Moderator
Well that is nice to know! If the dealer can fix it, I can with FORSCAN!
Plus there are a few more tweaks I want to do.
Thanks for the info! Good to know.
wakeboarder
Fort Lauderdale, FL
I have not updated to 3.4.
TXFRDOwner
So on the 2020 it's no longer under this line 7D0-01-02 **** - xxxx - xxxx
Door Keypad Menu (DKM) & Ambient Lighting (AL):
8=DKM disabled & AL disabled
9=DKM enabled & AL disabled
A=DKM disabled & AL enabled
B=DKM enabled & AL enabled
Moderator
What is the process to upgrade to 3.4 software ?
Do a search Donn, there is a thread in both the 3rd and 4th Gen areas discussing it. Ask in one of those if you have an issue, and one of us will respond!
Kmdcolo
Was it removed? F150’s had it 2015-2017 and then it was removed 2018+. The 2018+ F150 has different hardware (single color LED’s) but still has the proper wiring.
Moderator
It looks like that happened to the 2020’s. Going to confirm part numbers today or tomorrow.
Lou Hamilton
Have you tried changing the color in ForScan?
BCM 726-31-02 xxxx x*xx xxxx
0=Ice Blue - Ford, 1=Orange - Ford, 2=Soft Blue - Ford, 3=Red - Ford (F150 default), 4=Green - Ford, 5=Blue - Ford, 6=Purple - Ford, 7=White - Lincoln, 8=Amber - Lincoln, 9=Teal - Lincoln, A=Red - Lincoln, B=Blue - Lincoln, C=Green - Lincoln, D=Lilac - Lincoln, E=Yellow - Non-Standard, F=Ice Blue - Non-Standard
Moderator
Worth a try, but I don’t think the hardware is capable of it. Just like they did in the 150 in 2018.
Yaady
SoFla
2 Questions:
Thanks!
No Colour options either. I just realized that i dont have them on a 2020 Expedition Limited Stealth..
Moderator
Yep. They removed the option on the limited. Just 1 color.
