Limited - Ambient Lighting Not Showing in Sync
TXFRDOwner
So on the 2020 it's no longer under this line 7D0-01-02 **** - xxxx - xxxx
Door Keypad Menu (DKM) & Ambient Lighting (AL):
8=DKM disabled & AL disabled
9=DKM enabled & AL disabled
A=DKM disabled & AL enabled
B=DKM enabled & AL enabled
LokiWolf
LokiWolf
Super Moderator
Super Moderator
Richmond VA
What is the process to upgrade to 3.4 software ?
Do a search Donn, there is a thread in both the 3rd and 4th Gen areas discussing it. Ask in one of those if you have an issue, and one of us will respond!
Kmdcolo
Colorado
Was it removed? F150’s had it 2015-2017 and then it was removed 2018+. The 2018+ F150 has different hardware (single color LED’s) but still has the proper wiring.
LokiWolf
LokiWolf
Super Moderator
Super Moderator
Richmond VA
It looks like that happened to the 2020’s. Going to confirm part numbers today or tomorrow.
Lou Hamilton
Maryland
Have you tried changing the color in ForScan?
BCM 726-31-02 xxxx x*xx xxxx
0=Ice Blue - Ford, 1=Orange - Ford, 2=Soft Blue - Ford, 3=Red - Ford (F150 default), 4=Green - Ford, 5=Blue - Ford, 6=Purple - Ford, 7=White - Lincoln, 8=Amber - Lincoln, 9=Teal - Lincoln, A=Red - Lincoln, B=Blue - Lincoln, C=Green - Lincoln, D=Lilac - Lincoln, E=Yellow - Non-Standard, F=Ice Blue - Non-Standard
LokiWolf
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Worth a try, but I don’t think the hardware is capable of it. Just like they did in the 150 in 2018.
Yaady
SoFla
No Ambient lighting setting in the Sync Settings menu in our new 2020 Limited. According to Ford’s website all Limited should have it.
2 Questions:
1). Anybody with a 4th Gen Limited that is also missing Ambient Lighting?
2). Anybody else ran in to this and found a fix if it was just a setting somewhere?
Thanks!
No Colour options either. I just realized that i dont have them on a 2020 Expedition Limited Stealth..
LokiWolf
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Yep. They removed the option on the limited. Just 1 color.
Jefes_Shyt
