Catch cans anyone?
lam396
US
That's crazy! I'm gonna need to get a bigger can if this continues. But I guess I'm glad I'm not putting that stuff back in the system
Sent from my SM-G970U using Tapatalk
lbv150
Northeast
In the cold winter months I check and drain mine every 5-600 miles. Mostly condensation like chocolate milk. In the warmer months it is all oil and I check and drain every 1500miles.
st381183
New Mexico
Sent from my moto g(7) using Tapatalk
That video in NO WAY makes the case AGAINST catch cans. The guy rambles and bloviates and never gives a clear answer. So I went to the comments, and almost all of the comments support installing a catch can. It is a preventative measure to reduce blow by. $150 for a JLT catch can is cheaper than the issues caused by build up on the valves.
ETC13
TN
The second gen eco boost is already designed to eliminate the issue catch cans are trying to prevent. Dual port injection.
https://www.noln.net/articles/2785-...ow-about-the-next-generation-of-engine-design
M
mrmachinist
Louisiana
lbv150
Northeast
I have said it a thousand times... ANY engine with a PCV system will benefit from a catch can filter. And to the folks who wonder about the second valve cover, usually that is the clean air intake side, another can would have zero benefit there.
bushpilot
Houston, Tx
I made my on on my 2004 6.0L diesel....cause ford was dumping the mist back thru the turbo and into the inter-cooler, I mounted it low on the frame rail and put a drain in it so I could drain the crap rather then remove the (PVC can).
Im looking hard at the misimoto system because they use TWO cans (one for each side) and one of the cans is large at 12 ounces!
AKentPhoto
New Orleans
But yet my can still is keeping some nasty stuff out of the engine.....
That the dual port injection will force into the combustion chamber instead of attach to the valves...
You are not wrong, but the engine is now designed to handle it and the fuel systems are more robust so we all win there.
Moderator
It is designed to mitigate it, not eliminate it. Why have it there in the first place?
Catch Can’s are not a new concept.
It is a no brainer. Catch crap and prevent it from going into the Engine.
lam396
US
I added the extension to my can and in getting ready to head out on a road trip so I thought I would empty it. I was shocked to find about 5oz of fluid in it! It's been less than 600 miles. But sure I can keep up with this honestly. Photo is what the oil/ water looked like on a paper towel. 35b723129948d8fd9b304a035fae2551.jpg
