Ford quietly redesigned the thermostat in 2022...replace it
sixsix
Louisiana
Quick question for those that have swapped it out, how much coolant do I need to get? I guess you just have to drain the radiator? I got the new thermostat and gasket on the way, I’ll just need to stop by the dealership to pick up some coolant.
Wangle
Des Moines, IA
First towing trip with the new thermostat. About 100 miles round-trip. Going out, 58° outside, Transmission temp 201°. Coming back outside temp 90° transmission temp 216°. Mild rolling Hills. 7500 pound 28 foot trailer. 65 MPH.
sixsix
Louisiana
Got the thermostat swapped out this morning. Took a little longer than I expected, got hung up on the bolt on the drivers side. Would have been easier if I would have taken all the intake piping out of the way and the hoses off the thermostat housing, but I didn’t feel like taking all that apart. I did end up taking the top hose off the housing. Then I had an issue with the vacuum coolant filler I have. It wouldn’t seal off the little vent chamber on the coolant bottle. But once I figured that out I got it filled back up with no problems. Used a little more than a gallon and a half of coolant.
So before with the cruise control set at 60mph I was reading 228 degrees and now it’s at 199 and only gets to about 205 when letting off. At idle it’s at 195. A damn near 30 degree drop should make the whole truck much more efficient I would think. It’s nice not to hear the fans screaming all the time.
Dice Roll
Craps Table
These 2 statements are just plain wrong.
a - The Spark Plugs - The Motorcraft Sparkplugs currently being offered by ford are complete and total junk. PERIOD. NGK is the goto recommended by anybody that actually works on these EcoBoost Motors.
c - The Air Filter - Yes the stock paper filter, filters fine, but airflow through it is terrible. It also gets plugged VERY easily, and it VERY susceptible to moisture. Ford has redesigned the airbox in recent years to help with the water saturation issue, but still can be a problem. I don't recommend the oiled filters, because people over oil them when they clean them, and that causes issues. AFE, AEM, and I am sure other make dry cleanable cotton based filters that filter as good as stock, but allow more flow due to greater surface area, are less likely to get clogged again due to greater surface area. Then if we want to talk to the best filter out there, that would be Donaldson's powerCore. Amazing flow and filter.
What is the Donaldson part number for our trucks? Their site doesn’t list the 3.5, only a couple v8s.
CamMO
St Charles MO
swapped my tstat out to the updated one on my 2019, temps are staying around 195-200 like it should now. if you're trying to do this job cleanly its a pain to use the rad drain, it is very slow and leaks out of the valve. takes a long time to drain 1-2 gallons so the level is below the thermostat. made a mess but glad to have it done.
I noticed that the degas bottle cap is a 21 psi. has anyone had issues with switching this to a 16 psi cap? i know on the 4th gen explorers, a common problem of leaky radiators can be prevented by going from 21 to 16 psi system. haven't heard of any radiator issues on expeditions but am considering it....
Moderator
Sadly, you have to go to an aftermarket housing to use one on the Ford 3.5TT. It is a cylindrical shaped filter, and HUGE!
There is the complete setup with the PowerCore included for the 4th Gen Expedition. I am using a similar setup on my 2021 F150, and just the AFE Dry drop in on the Expedition.
Moderator
Nice, great data!
Moderator
I would not recommend it. It is not an issue on these.
bshowalter
Bellbrook
Another data point for this thread. Swapped to the new thermostat in my 2019 Max with Max Tow Package. Towing my ~6k lb boat with family and gear in the truck it ran 10-15 degrees cooler on average, both engine and trans temps. Highly recommend this update if you haven't done it.
F150 Pat
Sugar Grove, Illinois
I'm assuming the new style is only to prevent sticking closed but is not a lower opening temp. It's still a 190 opening temp. Was the stock a 190 or 195 opening temp? Does it need a gasket? I would assume it would but don't see it as coming with the thermostat
zak99b5
Albany N.Y.
I bought the gasket separate. My original one (was sticking closed) was 195*. Replaced it with 180*. I was under the impression that it had a 190*, so I figured ten degrees cooler would help but not be too different.
That said, I am totally happy with the 180*.
Hellwig
My 2019 Max Platinum just started running hot but so far it’s only on interstate when going up any kind of grade, doesn’t even have to be all that much. Usually when it gets to the peak it’ll show 235 degrees. I recently had 2 heater hoses replaced that were leaking and it didn’t start doing it till after that. I need to call the dealer back and see what they say. I may have to replace it myself tho, I can’t afford those high dealer prices…. They charged me $600 in labor to change the two hoses, and they were quick connects.
Any write ups out there on changing out the thermostat? It doesn’t look too terribly complicated.
How do you make the numeric temperature appear above the engine temp gauge? Forscan?
Hellwig
Did you buy your 180F thermostat from ebay?
Hellwig
How did you get the numeric transmission temperatures?
