J_82
I meant to say how much money have you spent on that upgrade alone.
About how much do you have alone? Not counting the LED and other mistakes?
I’m not sure if I want to void the factory warranty with an upgrade like that.
Don’t you have to splice in to the wiring to do the projector upgrade?
You have to run the wires in side the housings. They provide a round rubber plug that requires you to cuta 1" diameter hole in the rubber cap behind the bulb If you seal it with silicone you can make it fairly water tight. If you ever need to do a warranty exchange you can just order another rubber cap.The hid I meant, so they are plug ins. Does the housing need any modification to them?
Ok gotcha I thought you had to splice in the wire and cut a bigger hole in the housing.You have to run the wires in side the housings. They provide a round rubber plug that requires you to cuta 1" diameter hole in the rubber cap behind the bulb If you seal it with silicone you can make it fairly water tight. If you ever need to do a warranty exchange you can just order another rubber cap.
Nope. All plug and playDon’t you have to splice in to the wiring to do the projector upgrade?
