2021 XLT FX4 Halogens - Help!
keny01998
Arkansas
9005 is the right type for XTL low beam. If someone has money to blow, check out the GTR Ultra lightning from Headlight Revolution. I'm still on cheap Katana LED set that I bought two years ago.
maharoof
Dammam, Saudi Arabia
My first night driving my expedition I thought the same thing. Those stock lights are a disgrace.
I bought some led bulbs for my lows, highs, and fogs and now my expedition has the brightest lights out of all my vehicles.
Amazon has several bulbs you can buy. Installation is very easy and there are YouTube videos on how to do it.
Good luck
can you share the brand and model of bulb you purchased, will be a great help
Tmg115
Dfw
ViperVette
ViperVette
Elida Ohio
My Allas just arrived and I’ll be installing them this evening. I will get some before/after pics and let you guys know what my experience was.
Hoping it is as plug and play as others have said but since mine is a ‘21 you just never know?CDF71431-B0DB-46C1-8914-DCC55799C09D.jpeg2FDE1706-EB37-447D-8515-44C9E319AAAD.jpegF99B4C51-0781-435F-B7B2-078B885357ED.jpeg
DWs-TTEB
Evans, GA
@ViperVette i installed the same set back in Sep 2020 to include Alla fog and park/front turn signals switchbacks. To date no issues. Love them. In the rear I went with Sylvania LED taillight bulbs since they are designed to work best in a halogen reflector housing.
DWs-TTEB
Evans, GA
I used Sylvania led lights for all the rear end lights (license plate, reverse, running and signals)
ViperVette
ViperVette
Elida Ohio
Having not done this before, I’m guessing the wiring harnesses included in the box go between the new bulb and the vehicle plug? I was thinking the plug and play was simply unplug the halogen bulb and plug in the LED bulb?
What do I do with that extra harness etc?
Does it go inside the dust cover? The instructions are very minimalistic that came in the box.
ViperVette
ViperVette
Elida Ohio
Here are some shots of the factory halogens using my iPhone 12. Somehow it makes the factory bulbs look much brighter than to the naked eye.
IF they were really THIS bright I wouldn’t change them!
Low Beam halogen
High beam halogen
PNWExpy
Oregon
The harnesses came connected to each bulb on my set. But yes. Connect bulb, then harness, then truck. You might have to flip the plug if it doesn’t turn on. Also I just threw the harnesses in the housing behind the dust cover and let them hang. Could probably tape them or zip tie to something but it’s tight up in there. I haven’t noticed any noise or problems from them hanging.
