Update!
223,000 miles.
I did all the wheel bearings. And recently:
Rear window glass hinges.
Another front ball joint.
Front sway bar links (again, which got rid of an annoying knocking).
Radiator replacement, it developed a 4” hair line crack in the plastic top.
Fuel tank leak fixed with epoxy - the front breather hose fitting had a small split.
New fuel pump.
Replaced fuel filter.
Replaced failed brake light switch.
Currently on the bench: Replacing the fuel pump relay that’s soldered into the main board in the fuse box. I hope this will fix the getting-more-frequent unpredictable stalling.
Further update!
The soldered fuel pump relay fix seems to have worked. Hallelujah.
I still love this vehicle! I also appreciate the huge help provided by other posters in this forum. I wish all well in this new year.
Graham
Front left window regulator has failed and i suspect driver side will do soon. Part coming today, hoping for an easy swap out. 227,*** mls
207xxx. Lost compression in #3 and #4, replaced head gasket, valve cover gaskets, new timing chain guides as 2 broke, new timing chain, new intake manifold, new coils, new performance injectors, new spark plugs, yes I do new harmonic balancer, new AC compressor and condenser, new idle tensioner and pulley, new pulleys, new MAF sensor, new tranny filter and tranny fluid. I literally just got done doing all of this as she has been benched for the last 3 months. I get done refilling all her liquids and I go to start her but she's not catching or even trying to start, I smelt gas, looked underneath for somethingeaking
. I see gas going on the ground from the back of the engine. I jump up in there and on the driver side ots wet with gas. Trying g to figure out where it's coming from.. hopefully it's something simple..
I have found some connector tools for $10-15 that allow you to simply release the wire from the plastic connectors and swap the plastic only from a junkyard donor in like 2-3 minutes. Beats the heck out of cutting, soldering etc... on short wires at arms reach. Something like these:Ticked over 250,000 miles last week!
Since last repair report I can add:
Replace brake booster as reservoir was full of gunk.
Spark plugs again.
Soldered on replacements for a couple of broken injector connectors.
I‘m concerned my repair on the gas tank may have started to leak…
225,000 on an 06 Eddie Bauer did timing chain at 170 phasers everything great truck love it plenty of power 2 inch lowered Springs a little bit of a suspension upgrade big brakes the thing is fantastic it's my highway Cruiser love itAs I've shared in earlier posts, my '03 Expedition is about to hit 200,000 miles. I bought it new in '02 and it's been the best and most reliable vehicle I've ever owned. It's been well maintained mechanically and I'm planning to keep it. I'm cleaning it up cosmetically now and am probably going to invest in new tires and shocks soon. But at some point, one has to wonder what the 2nd Gen's life expectancy is and therefore how much money should I invest in it.
So, I'm curious how many miles have other 2nd Gen owners have racked up on their Expeditions?
Mako
208,000 and going strong I love this SUV did timing chains at about 160 phasers the whole nine yards it's been greatAs I've shared in earlier posts, my '03 Expedition is about to hit 200,000 miles. I bought it new in '02 and it's been the best and most reliable vehicle I've ever owned. It's been well maintained mechanically and I'm planning to keep it. I'm cleaning it up cosmetically now and am probably going to invest in new tires and shocks soon. But at some point, one has to wonder what the 2nd Gen's life expectancy is and therefore how much money should I invest in it.
Mako
