07navi
Flushing the brake fluid is not something you need to do often (algae can actually grow in it) and I just flushed mine after 180k miles, also the little brake bleeder tool is very easy to use and is a one person job. With limos you probably need to be on top of the brake issues more than I am, I can see that.Ideally, my pass will have some sort of built-in chirpers which not all do... And once they start chirping I will know I don't have much time left to replace them until a a pad backing plate hits the rotor. But if one does hit the rotor slightly and you take it straight home it's not too big of a deal.
I don't like using the vacuum pumps at all.
I would be okay with the speed bleeder idea but I haven't actually use them either.
I always have someone pump the brakes.
I rarely even bleed them when I replace pads but I will sometimes open the bleeder screw and pump the fluid that's in the caliper out when I press in the piston.
I just had a set on a very large Town Car but I could feel we're getting thin when I push the pedal. There was a slight little bit of pulsation because the rotors were quite old and had some miles on them but more than anything I could just feel a roughness from the thin pads. When I took them off, sure enough, they were down to awfully thin to where in few more days they would have probably been cracking and sliding off the backing plates.
