So I got a good start on my roof wiring project. I have had a few ask about the Switch-Pros. The original pre wired switch was the Spod. It uses relays and fuses but had everything was pre wired. Mainly for Jeeps. The SP has a small panel with 8 switches and one control wire. It is all solid state. No relays or fuses. You have 4-20 amp and 4-35 amp circuits. You can actually program the fuse settings, delay, on/off, momentary, dim,strobe, flash or even combine one button to turn everything on. It also has 2 trigger wires for high beams, revere signal or what ever you can dream off. It’s Bluetooth and you program and can control the lights from your phone. It runs about $550.00 at any distributor. So it is a good bang for your money. If I was to do it again I would try the Spod Bantam with the touch screen controller. It is now solid state as well but a lot more money. The box is huge compared to the SP. But it has a place to land all the ground cables and wires. The SP just had wires you splice into and ground to the frame.
