Replace Roof Antenna
brett1210
St. Paul, MN
Does anyone have any tips for removing the roof antenna on a 4th gen Expedition? I need to replace mine and have not found any sort of guide after doing a search on the forum. Thanks in advance.
B
brett1210
St. Paul, MN
The paint has completely peeled off the front and sides. My Expedition is white so it’s a pretty big eyesore right now. I’m planning on buying a used one from eBay and just replacing it. They are about $150 from the junkyard.
duneslider
Utah
Just thinking outside the box here but wouldn't it be easier/cheaper to just get some paint that matches fairly close and paint it? I can imagine a can of white touch up paint from the autoparts store costing more than 10-12 bucks and would last you for a handful of touch ups. Mask it off spray it an be done. Just a thought.
B
brett1210
St. Paul, MN
Not a bad thought. If I can’t find any info on how to remove it then I may go that route. I was thinking if it was going to be an easy job without much risk of breaking anything then I would just go for it, but I don’t want to start removing trim pieces blindly and end up breaking plastic clips.
Dahammer
Have you checked your Ford service department to see if it's covered under warranty?
