that seems to fix more problems than not in my case. My trans was making a clunk going into and out of OD, went and drove through a field and did some donuts and other fun stuff. ended up getting stuck and had to go from R to D to rock it out. after that the od shift is not really noticeable but it is still working as it should. for a couple days after it took a second to engage reverse but all is normal after a week of driving.
I have learned if you are going to baby the throttle you should at least blow it out every now and then.
I really don't have a problem blowing it out every now and then...
Hell.... if I could make it through a tank of gas without doing it at least once it would be a miracle.
