Lug nut insanity
Adieu
SoCal
No it's not considering you pay $5 or $6 each for the crappy ones from the dealer. These are $4.38 each which includes free shipping if you are a Prime member.
Mine are <$1 a piece w/ 10% off sale, wheel locks, and didn't even suffer any finish issues from getting impacted on
Considering the shittiness of OEM, i don't think the "pricey = quality" expectation works anymore
Flexpedition
midwest
you’ve not lived until you’ve purchased lug nuts for the 22 inch F150 Harley Davidson / Limited wheels. 6L3Z1120BA Is the part number. MSRP runs about $26 each.
These are the only lug nuts that allow the unique domed center cap to be attached.
gixer2000
Retrofit or Bust
Massachusetts
Thank you for saying that. I'm actually looking at some Harley limited wheels local and the guy doesn't have the lug nuts with them. Sounds like I should beat him up on price a little
BlueStangGT
Oklahoma
Just went through this on my 125k mile 07 Expy. The correct socket size is 13/16 and I had to hammer my socket on about half of them due to swelling. There were two lugs that were swollen so much I had to move up to a 7/8 socket and still had to hammer them a little bit. I had to use a 3’ breaker on about half a dozen lugs... used Dorman OE style lugs for replacements.
Edit - calling the 13/16 “correct” is inaccurate on my part, it just turns out that it worked for my situation on lug nuts that were destined for the trash can anyway. It did, however, fit the Dormans perfectly.
Adieu
SoCal
Uhm, they're so fooked BECAUSE you've been using SAE sockets.
Fords are 100% metric. NOTHING original on your truck uses inch sockets
briandye
I picked up my 2008 about 2 months ago, ordered a lift/level kit for it about a week ago.
Went to start installing yesterday, never done one before, I was a little intimidated.
Come to find out, getting the f*cking wheels off would be the hardest part! My passenger front wheels lugs were torqued to what I would assume would be 1,000,000 ft/lbs. I made the mistake of using the 13/16(?) socket to try to get them off. Jumping on my 24” breaker bar. (I’m 260lbs) broke 3 loose while mangling the stupid caps, one cap game right off leaving the bare lug, and I had to pry and rip the other two caps off and hammer a 19mm on to get them off.
After leaving for a hardware store trip for a few large impact sockets, I found that the 21mm deep impact fit PERFECT on the rest of them.
I ordered Dorman replacements, they’re nearly identical to mine, Advance and Autozone only stock ONE pack of them, they come in 4. We need 24. So I bought the one pack at Advance, and Autozone for about $13 each, and then ordered the same 4-pack (4 of them) on Amazon for like $8 a piece.
BlueStangGT
Oklahoma
Really, not even the spark plugs? lol
Thanks for jumping to conclusions, this is the first time I’ve ever put a wrench on ‘em but I’ll definitely be having a conversation with the tire / brake / alignment shop I’ve been using for the past 10 years. The old ones were pretty beat up and all of them were swollen to some degree but 13/16 did the trick and fit the replacement Dormans perfectly.
gixer2000
Retrofit or Bust
Massachusetts
13/16 always fit the best on my oem lug nut and the plugs are absolutely 9/16
BlueStangGT
Oklahoma
What was the difference in fitment on your Dormans between the 13/16 and 21mm?
Adieu
SoCal
13/16 is 20.63mm... if it's forced on and/or not all the way on and an impact is applied to it, it wouldn't be helping an already fragile lug nut design
Adieu
SoCal
Oddly.... it seems part of the spark plug problems with early Tritons was that they're ACTUALLY 14mm and people using 9/16" on em wasnt helping things
It actually cuts both ways. There's a shitton of European stuff labelled 13mm or 19mm that's actually 1/2" and 3/4".... hell, 7.62mm is 300 mil / 0.3"
Ben Ford
Goose Creek, SC
Currently replacing my lug nuts with solid ones. This is what you have to do to at least one just about every time you remove gen stock ones.
This is super helpful!!! I was unsure why I couldn't get the front tire off of my new to me as of yesterday 2007 Expedition EL LIMITED. No matter the socket or even the stock lug removal tool I couldn't remove the lug nuts. I'll update ya'll when I get mine replaced with the link that you provided!!
Sent from my Moto Z (2) using Tapatalk
sjwelds
Kansas
Ok guys, got a question. I bought these new used lug nuts from @ExpeditionAndy and need to swap them on. Could I just take one off at a time, run the new one on and torque it, and repeat in a star pattern, without even jacking up the vehicle? Do you see any problems with that plan?
Edit: yes I know I could wait until my next tire rotation, but I'd like to do it soon, as the old lugs look kinda crappy.
ExpeditionAndy
Fort Wayne, Indiana
That what I did. I took them off one at a time with the wheel on the ground and followed the star pattern and used a torque wrench to set the proper torque. It worked fine. :) Post pictures once you have them on.
ExpeditionAndy
Fort Wayne, Indiana
just so you guys know this is nothing new for Ford
My 1977 Mustang had the same type of lug nuts
In theory capping them with stainless steel would keep them from rusting but in application, using short sockets is what eventually destroys them, because it twists only part of the cap, eventually making it impossible to get a socket on them because of the deflection of the cap.
JHolden
Maine
The lug nuts on mine are swollen and over tightened. I just sheared the factory supplied tire iron!! Once you get the chrome off what’s the size of the nut?
No members online now.
Landsbutter
