No_Expedition
I’m in if you start offering builds.
Nice work on these. Want them mostly for the more modern look they add to the front of the truck. Dont have any troube seeing at night, thats why I'm interested in doing this w/ less expensive parts.Finally Closing them up!!
Put some temp caps on the back till the right ones show up and picking up some techflex to cover the wiring
Yeah, you should have a top model like these, then a value model that has the same construction w/ lower cost components. Maybe even a low-cost leader model w/ the lowest cost parts that are still reliable...I’m in if you start offering builds.
I was thinking any projector with a threaded shaft. The Morimoto D2s 5.0 just came out and performs very close to the RX350. The threaded shaft is what makes a build simple so offering anything with custom mounting just won't happen. I just don't have the time for that. With a threaded shaft build I can turn them around in a few days depending on paint.Nice work on these. Want them mostly for the more modern look they add to the front of the truck. Dont have any troube seeing at night, thats why I'm interested in doing this w/ less expensive parts.
Oh yeah, that makes sense. Is the D2s the most affordable projector w/ threaded shaft then?I was thinking any projector with a threaded shaft. The Morimoto D2s 5.0 just came out and performs very close to the RX350. The threaded shaft is what makes a build simple so offering anything with custom mounting just won't happen. I just don't have the time for that. With a threaded shaft build I can turn them around in a few days depending on paint.
No, the mini H1 is but the output isn't as good as the D2s. I believe there is only a $30 price difference between the 2Oh yeah, that makes sense. Is the D2s the most affordable projector w/ threaded shaft then?
When we are going to see your custom build in action?Finally Closing them up!!
