ForScan Tweaks - 2015+
Super Moderator
Super Moderator
I haven't seen how to add the Climate menu the the right MFD on the ForScan google doc. Can you give some insight on how you got it to work?
You can’t on the Expedition. Those pics were from my Edge before we tested the Code on the Expy.
star-art
Pacific Northwest
For the IPC right side climate controls mod, has anyone tried the following:
IPC Module line 720-05-01
First set of numbers, change the code to "D8B8"
I saw this demonstrated in a YouTube video. It wasn't an Expedition, but it was the same instrument cluster.
PS My code is "D878" for an XLT with 202A package
Super Moderator
Super Moderator
Nope won’t work. No other Ford vehicle has the module combo we do.
star-art
Pacific Northwest
So frustrating! I thought tire pressures were handled and broadcast by the BCM? What other module is involved that we don't have? Is it by chance the Driver Door Module? Thanks! :)
Super Moderator
Super Moderator
BCM knows the pressures, but no code involved to display them. You can use a BT OBDII adapter and OBDLINK to display them, at least on my 15 and 17 I could/can.
Yes, the thing limiting our tweaks the most is the lack of DDM and PDM.
TXFRDOwner
What Hex Bit did you change to display the TPMS menu in the IPC ?
Super Moderator
Super Moderator
You can’t. You use the BT adapter to display it on your phone.
TXFRDOwner
So the 15-17 Expedition BCM Configuration menu doesnt display this like the Fusion
sharprd65
