Catch cans anyone?
Moderator
Yeah I was amazed that it was full, and was mad at myself for taking so long to put one on it.
Sent from my SM-G975U using Tapatalk
In the winter it is mostly water vapor. Same amount of oil, at least based on watching mine separate, vs summer collection amounts.
Millerwelds1
Derby, Ks
Yeah, it had the viscosity of water with a little oil in it. Makes sense.
M
mrmachinist
Louisiana
Well tried to drain the can. About 2300 miles on it and nothing came out.
I pulled it off so I could unscrew it and see inside.
It’s a layer of thick oil. Almost pudding consistency. About 2 oz.
Anyone ever get anything like this?
3tonsoffun
Jesus, not that thick. What brand can?
lam396
US
Installed the JLT on my 19 tonight. Had to mount it slightly differently than the instructions said but otherwise it was a simple install. My wire harness was further to the right than other photos ive seen which is why it didn't want to fit, just had to flip the bracket over. 5070c01929d4cd77abb5704eb5c4fc1b.jpg9a50777edd4e5a582db45287240c5b5a.jpg
Sent from my SM-G970U using Tapatalk
3tonsoffun
Don’t forget to clean the filter in there every 10k
lam396
US
Didn't realize there was a filter on top also. Good to know! Guess that makes my mounting solution a little more annoying to deal with
3tonsoffun
Yeah you’ll need to remove the entire assembly to clean the filter
bushpilot
Houston, Tx
there are some cans that spin off just the bottom.
theres also some that say you need a can for both valve covers.
Moderator
Yes, thanks for restating what has already been discussed in this thread, and the others about Catch Cans.
[emoji849][emoji23][emoji482]
bushpilot
Houston, Tx
5 pages - you expect everyone to read every reply?
lam396
US
This doesn't seem right, I'd guess I have less than 1000 miles on this and it's full. Very oily consistency, with some froth at bottom. Could it indicate something wrong with the engine or is it purely environment driven? bae76d4e8f1f57f3b474865263651db7.jpg737e796780e82ad7efa134a61b41ef62.jpg
Millerwelds1
Derby, Ks
Yeah mine is the same way, have to check it every 1k. If you look at the consistency of it it should mostly be water, with oil in it.
