Thanks again for the wealth of info all of you share.
TobyU-I always love your thinking out loud posts! My brain works the same way so I get a lot out of your advice. I don’t know if it’s an intake or exhaust valve-how do you tell. If it’s from location, it is a valve on the lower (towards the drivers side fender) side. When I did the compression test (seems like ages ago), the needle did not even move-on either wet or dry test on this cylinder. Dual or single springs-I only see one per valve (obviously 4 per cylinder on this).
rjdelp-I really don’t think this vehicle was poorly maintained. I do have a few records for it and it appears it was pretty well taken care of. I don’t believe it burned oil, but of course I don’t know for sure. I will try to find some info on the leaky exhaust valves for this motor-thank you for the suggestion.
So I will plan on the air test and report how it goes and we’ll go from there!!
You are one of the few! Lol I ramble on and spew off topic info....as you said, thinking out loud.
Remembering now this is a 32 v so 2 intakes and 2 exhaust valves.
You can look up a diagram for valve orientation or look to see which one i tin the intake runner of the head and which ones are closest the exhaust ports.
If one is lower than other it is probably stuck open and this would give 0 compression.
This is a little unorthodox but if you you can get the valve to close and seal----you COULD leave it closed and the follower off and still run pretty well.
As long as the valve is closed....A non opening valve on a 4 valve..the other valve will still let air in and out just not quite as much. It's not like half. More volume will go in or out the only one that is open and I bet on many engines if you disabled one intake or exhaust (esp exhaust) you couldn't even tell.
But the ? is why is it open if open. If has to seal almost perfectly.
A valve that looks closed but only has a sliver of light getting through will kill your compression.
DO the air test to see where it is leaking and we'll go from there.
