ForScan (adjust tire diameter in MM)What do you guys do to adjust the speed and fuel useage?
As mine is about 7% wrong due to the 315 tires?
There is also a calculator (probably accessed in the ForScan page) as part of the F-150 spreadsheet that will use GPS speed versus speedometer speed to give a value to put into ForScan.What do you guys do to adjust the speed and fuel useage?
Yes.thanks, so in short,
I purchase a usb cable like this: https://www.amazon.com/dp/B094Z7PBLS
and download forscan and adjust the values that reflect my current setup?
This also fixes the mpg differences and my distance counter? (although I kinda like my total miles drived overall doesn't reflect the actual number (as it is off by 7%)
Any idea on the full scope of work to get that? Is it stock with bigger tires? A readyLIFT and bigger tires? A full coil over upgrade and bigger tires?Not mine, for sale at my local dealership for you guys or gals looking at the 2022's
285's
Looks great! - thanks for making me decide on keeping 18's rather than moving to 20's on my Timberline. (have 35 x17's on my Raptor and Rubicon and love meaty tires) Is that a 18x9 0 offset wheel?View attachment 73543
Rough Country 3inch Kit
295/70/r18 (34.5”) Cooper Discoverer AT3 XLT
Pro Comp 40 Series Vertigo Wheels
Relocated Fender Liner
16.5 inches of clearance at running boards behind front tires. 17.5 inches of clearance at running boards I front of rear wheels.
No rub whatsoever with this setup
