Raptor Steering Wheel Install
Moderator
@LokiWolf and @DWs-TTEB - you two seem to be very familiar with these vehicles, do you have any advice on getting the steering wheel perfectly centered again after putting the raptor wheel on? Or would this really need the extreme of an alignment? I've tried probably 6 or 7 times, holding the wheel slightly to the right while torque-ing it down. Doesn't seem to make a difference.
@DWa-TTEB has a good suggestion.
The other is FORSCAN. These have Electrically controlled steering. I know there is a process to adjust steering wheel position on other Fords. I did it on my Edge. It was also off Center despite driving perfectly straight. Way more than yours. Haven’t tried anything like that on these...but the theory is there.
5280tunage
colorado
Whoa, now that is definitely not something I would have thought of looking at. Will do. Thank you.
Maybe I'll ride with it for now and have the dealer do an alignment once the rest of my stupid parts are in.
5280tunage
colorado
Off topic here, the boost gauge (4th gen expys) is the combined PSI of both turbos or for each singular?
@5280tunage
@LokiWolf
That's funny, I was literally thinking about that yesterday.
So based on Loki's response, it's both combined. So they are relatively small turbo's each then, like max 8-10psi-ish? Don't get me wrong, I love them, that's half the reason I bought this thing.
5280tunage
colorado
I like the upside down ideal as well!
So interestingly, having the bolt go from top to bottom was a pain in the ass. For one, the brake lines and wheel speed lines, etc, were totally in the way. You can move the bolt around and get it done, but in the config, gravity is not your friend. Suppose it doesn't help that I was under my vehicle without it on ramps when I was swapping them but it was definitely a little more work than going bottom up. I'll also say, I cranked them down a little tighter this time and I think it helped.
Also, don't crank either but down till the are both on. You need play in the bar at first.
Alhrir1982
SAUDIA ARABIA
Hey all, have a question for the group. Take a look at the picture below. You may notice the wheel is slightly rotated to the right, but this is when the vehicle is tracking straight on the road. I've tried half a dozen times to take it apart, rotate the wheel partially the left before locking down the bolt holding the wheel in place. There are two guide posts on the steering column that really prevent the wheel from going on crooked, but no matter what I do it's just a few degrees off. Does anyone know of a trick to get this straight again? Or is it a ridiculous matter of getting an alignment?
I know, it's just a few degrees, but it drives me nuts that its not perfectly centered while tracking perfectly straight. Would love some ideas.
Oh, and how annoying, I was next to a Honda Pilot today, newer but not current model, and it had paddle shifters. Those things are half the price of the Expy, what a sham.
I also installed a Raptor steering wheel
I notice the steering wheel turns a little to the right while the vehicle is straightening
5280tunage
colorado
That's exactly like mine. Frustrating. I have another warranty service scheduled for next tuesday, told them I'd like to try an alignment. I'll let you know if it helps. It makes no sense that it's off like that, nothing else in the steering changes, so i'm wondering if the actual cast between the wheels is a little off. Love the wheel though. I was actually playing around with the paddles today. It's really interesting to see the power bands and when/how the turbos kick in. Never really noticed it until I started driving with the paddles. It's not at all like my previous turbo'd vehicles.
Alhrir1982
SAUDIA ARABIA
thanks
I’m waiting
TheDoug
Mansfield, TX
That is a bummer the wheel is not lined up correctly, mine did not have this issue. Hope it gets resolved
Jimmer
Eau Claire, WI
The steering wheel on my 2020 shorty is titled about 5 degrees to the left at 5k miles (at about 830 and 230 instead of 9 and 3). Such a small thing but really bugs me sitting behind the wheel on long trips. Did anyone ever find a remedy to the situation? I dont mind paying the $100 for an alignment if that fixes the issue; my knowledge is pretty limited but since the wheel "auto centers" itself crooked, and the vehicle drives perfectly straight with my hands off the wheel at that (off) centered location, my thinking is the alignment is fine but the steering wheel is just off somehow?
I remember reading somewhere on here that the electronic steering has some sort of learning functionality that takes a bit to "re-learn" after the battery is disconnected. I'm going to try that tonight and see if maybe that electronic reset will bring it back to where it should be.
Will report back on that but in the mean time if anyone found a solution, or if an alignment will take care of the issue, any input would be appreciated!
5280tunage
colorado
An alignment on mine fixed the wheel center issue. Technically its one of several things they do during an alignment, so even if the other stuff is fine, they can still straighten the wheel. They actually did mine at no cost, as I told them the same things you did, and there were no obvious signs of impact or anything else, so the dealer took care of it. I wouldn't mess with the Forscan stuff.
Jimmer
Eau Claire, WI
Awesome, exactly what I needed to know. Thanks for the help!
Brick,nj
I installed one yesterday which I need to take out and switch wiring and front bezel with the buttons from one steering wheel to another as there are different functions on both. Didn’t notice that until I tried all the buttons and some where doing other functions from another button. Once I do that I’ll take it for a spin and see if it’s straight. Unlike others that disconnected the battery, I did not. I just let it sit for like a half hour to make sure nothing was still on. I’ve done that with all my vehicles with no issues of the airbag going off.
5280tunage
colorado
I hear ya, but that's pretty risky. I'd say why not disconnect the battery? Takes me 20 seconds to reset a few options. I've personally seen what happens to someone when that bag accidentally goes off, nearly killed an alarm installer as he was working just below the steering wheel when he hit one of the yellow wrapped sets of wires with the wrong type of tester. But I'm glad you managed to do it safely. The number of times I took mine apart to try and straighten it (when really I should have just got an alignment), the risk was just too high. Not to mention replacing an airbag that is probably over a grand...
Brick,nj
Just a follow up. I installed the wheel and went for a drive. As others have mentioned it is about 2 degrees off to the right. As I’m like most it bothers me, so I did some tests from the stock to this wheel. When installed both wheels there is play from right to left before tightening the wheel with the center bolt. I’m guessing like everyone when we tighten the bolt the wheel pulls right unless you have someone helping you. Since I noticed the play before tightening again I moved the steering wheel as far left as I could do by myself when tightening the bolt. That seemed to fix the wheel 99.5%. To get it dead straight on you need another person just to move the steering wheel a tad more to the left.
hope that helps
Hannah121107
Sacramento
This was a very simple and straightforward install and I’m 90-95% satisfied with the results. It was essentially plug and play as all the wiring was present and all I had to do was move the trim and switches from the original to the Raptor wheel. I’m really not a fan of the red stripe so I’m still deciding if I’m going to modify the original wheel to fit the Raptor shift paddles, have the Raptor wheel reupholstered with the tops and bottoms from the original wheel or leave the red stripe and add touches of red to the interior so it has something to tie in with the rest of the interior.
View attachment 23847 View attachment 23848
Could you possibly let me know what else is needed for this install? And where you bought them from? Would be super helpful. I want to do this mod.
Thank you
BMW2FORD
CT
Quick question to everyone with this wheel and the paddles set up - do you have to press the “M” button on the center console shift knob to begin using the paddles to shift or can you shift just directly with the paddles at anytime? Thanks in advance!
TheDoug
Mansfield, TX
Pressing the M is the only way to use it as a manual shift.
Without pressing the M, you can press the downshift paddle to lock out gears. For example while on my road trip to Colorado passing through the mountains, on long downhill stretches I downshifted to 6th or 7th to prevent the transmission from going to any higher gears so I didn't pick up too much speed.
5280tunage
colorado
On mine I can use the paddles anytime. I don't think I've pressed the M button since I put the paddles on. It may be a confusion of terms, but anytime I'm driving I can down/up shift. As TheDoug stated, I use them all the time to engine brake in the mountains, but even at a stop light for example, I just use the downshift paddle to start the truck off in first, then nail the upshift paddle to go into 2nd, 3rd, etc. Never once hitting the M button. I hate the design and placement of the M and +/- buttons, which is why I did the paddles. I use them a ton in the mountains.
The placement of the buttons seems more like a checkbox, hoping that soccer moms driving these big things will essentially never use them. All the arguments about can't use half the radios features while driving (preventing you from taking your eyes off the road) but the awkward buttons by the center console are soooo much safer.
