The "Auto Stop-Start" is so annoying!!!!
Plati
Just tried using FORScan v2.3.28 on my brand new 2019 Expedition to disable ASS. The FORScan tool says "additional change required in IPC" next to the Auto Stop Start option toggle. I toggled it to disabled and ASS.
ASS is disabled after this change, however I get a "Charging System Service Soon" message on startup that I have to clear by hitting OK. Changing ASS back to enabled in FORScan no longer triggers the charging system error, but I'm obviously back to square one.
How does one make the change in the IPC referenced in FORScan, or is that something that is not currently possible with the existing FORScan version? (I do have the extended license)
Any help or pointers would be greatly appreciated!
This doesn't help other than add context .. but I know from my experience with big Xerox printers that NVM (non volatile memory) values that control features/functions/timing/whatever are often done in multiple memory locations. A Xerox tech bulletin would say "change this location to that value & also change this location to this value if you want ABC or that value if you want DEF", etc. It was all tightly controlled by the Engineers. They don't want customers fiddling with those values. I'm sure you figured that out but its a black magic area. When you change a value you essentially change the software that's running the machine. I think it could be compared to the Registry in Windows.
carymccarr
Earth
Why is turning it off with button at start so bad?
It’s just annoying. Same as if you had to turn a button to ‘off’ every time you got in the car to keep the horn from honking every 3 seconds.
Therabbittree
Red Hook, NY
I normally use sport mode and it auto shuts off auto start. Still need to switch to 2H then though.
Artie
Georgia
I wonder this too lol Idk where the button is for the Expy but in the navi it’s right next to the e brake and I always engage it so I’m right there anyway to disengage...so hitting the ASS button is just second nature to me now.
Deadman
I'm assuming you guys are retired, or something that you have all this spare time on your hands! lol
Artie
Georgia
I mean, sorta. I’m a 42 yr old stay at home dad... I have two toddlers. I used some of my spare time to time how long it took from me to press the ASS button... it was about 2 thousandths of a second. I think my spare time is safe.
For real though... does the Expy not have a convenient button to push? The navi has one right next to the e brake which is right next to the drive mode knob. In the time it would take me to disable this feature in FOREscan I could press that button every time I drive the vehicle for the entirety of its ownership and still have time to spare.
