This doesn't help other than add context .. but I know from my experience with big Xerox printers that NVM (non volatile memory) values that control features/functions/timing/whatever are often done in multiple memory locations. A Xerox tech bulletin would say "change this location to that value & also change this location to this value if you want ABC or that value if you want DEF", etc. It was all tightly controlled by the Engineers. They don't want customers fiddling with those values. I'm sure you figured that out but its a black magic area. When you change a value you essentially change the software that's running the machine. I think it could be compared to the Registry in Windows.Just tried using FORScan v2.3.28 on my brand new 2019 Expedition to disable ASS. The FORScan tool says "additional change required in IPC" next to the Auto Stop Start option toggle. I toggled it to disabled and ASS.
ASS is disabled after this change, however I get a "Charging System Service Soon" message on startup that I have to clear by hitting OK. Changing ASS back to enabled in FORScan no longer triggers the charging system error, but I'm obviously back to square one.
How does one make the change in the IPC referenced in FORScan, or is that something that is not currently possible with the existing FORScan version? (I do have the extended license)
Any help or pointers would be greatly appreciated!
