Another retrofit started. RX350!!!
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
I built a little jig today out of unistrut to allow easy alignment for 07-14 buckets. It can be adjusted any direction to fit the work area whether it's level or not and works pretty well. Nothing fancy but may allow me to do more retrofits in less time and guarantee the alignment is perfect.
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
Finally got my alignment finalized. I've been so busy I haven't had time to touch these but hoping for more update pics shortly. I'm really excited for the output on these becaise they destroy the mini h1's I have now.
Pic 1- auto mode
Pic 2-ISO 200
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
Got the retro rolling again this week. Projectors are permanently mounted in the reflector and I locked them in with JB weld tonight. Hoping to have these closed up this week.
crector080862
US
Well dang those look nice I want a set
Sent from my SM-G892A using Tapatalk
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
I think your alignment is off because that light line is not straight at all
Are you talking about the step? The step is normal. Each projector has it but you really only see the drivers side because the passenger side is washed out by the drivers side.
Pretty normal for the cutoff to arch toward the end and I leveled everything with a laser level so its all good. I'm also not parked in an area that's level and this spot was more used to show the width.
John Schwab
VA
This does not look normal. I’ve never seen any car that has that drastic of a difference in being level. I bought SL1s for my 2016 and they look better than that??
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
That is the drivers side cutoff. If your 2016 doesn't have it then you may wanna take a look at the bulb seating. If you have reflector housing on the 16 the cutoff will be less pronounced anyway but still exists.
There is some glare there from no shrouds being installed yet but that will be gone once the shrouds are painted.
Heres a shot with the camera ISO turned way down so you can get a better idea of whats happening here. Every projector has this cutoff and some larger that others but the low area is to keep the light oyt of oncoming traffics eyes.
Also in that first picture above, the passanger side is slightly higher out to the right side of what you have circled. I wasn't working on vertical adjustment because that will happen once the lights are installed. Here I was checking rotation and distance apart.
John Schwab
VA
Looks like it’s out of vertical alignment. Stock cars have a clear crisp distinct line tht has no driver side break. I have projectors and from factory and after I installed SL1s it has retained a crisp straight line
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
Its not a drivers side break. Its the cutoff! EVERY projector has it, even your 2016 has it if you have projectors! Like I said above on some projectors its more pronounced
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
Also keep in kind that OEM lenses on the fords are either dimpled or Fresnel which would make the cutoff cloudy and tough to see in some case.
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
Welcome back David! Coming to stir the pot some more?
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
I’m actually J Ski, and no just trying to figure out some stuff on these retro fits that’s confusing me that’s all
I know who you are!
So basically the left side in the US is lower to allow the light in front of you more distance but keeps from blinding oncoming traffic. In Europe its the exact opposite. The projector lense clarity and projector design plays a huge part in how defined the cutoff is. From the factory most are setup to provide just enough light to get a DOT approval.
Muddy Bean
Gixer is right. His setup and cutoff look perfect. If you’ve never seen a cutoff like that, you’ve only ever seen the junkiest HID kits. Simple google search revealed these glorious images:
a19a1bdc52502d6fb2c21e42d0240f6f.jpga66cc155d0e86f0b9bd2249462a76851.jpg7153f78170a1ba2252b313dc2318b42e.jpgc646a699e38de19f32591c30aeff41b5.jpg
So yes, cutoff is indicative of a properly setup projector and Gixer absolutely knows what he’s doing when it comes to headlight projector and HID retrofits. I chuckle when people argue with him because if you take the time to read through his posts on headlight tech, he absolutely knows his stuff... smh
nightfly
Reanimator
NJ & AZ
That light pattern is exactly how my Cibie 'Z beam' halogen 7" headlights looked back in the 80's.
gixer2000
gixer2000
Retrofit or Bust
Massachusetts
And they still aren't closed up.. :( but I got the shrouds epoxied on, moisture vents installed as a precaution and everything is dust free. Closed for sure this week!
Why not another wall shot
